The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
DYNOJET: Power Vision Target Tune
Old 06-16-2024 | 11:25 AM
xxholdxx's Avatar
xxholdxx
6th Gear
Exclamation
manually updated
same tune file after autotune session
The top table is the one I manually edited the bottom is after 3 auto tune sessions, 2 spark max learn with ve off and 1 spark learn off and ve on. In the settings for AT I set the max lambda learn to .95 yet it still has some that would be considered 1.
the only thing i can figure is Im missing something. so on my next ride I'll turn autotune off and see what the table looks like after the ride
  #172
Old 06-16-2024 | 01:14 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Just to let you know, I stopped Auto tuning because every time that I did it would lean out the bike way too much... So what did I started doing data logging and looking at the correction factors and figured out each individual cell where I had to make changes to get it to where it should be based on my set AFR table.. Some people think I'm a little rich at different KPAs in my tune but I'd rather have it a tad rich because the motor is definitely built with 11.26:1 compression.. It's just the way I've learned to do it and it seems to work pretty well My only issue is I cannot get my idle chill out...
  #173
Old 06-16-2024 | 04:26 PM
xxholdxx's Avatar
xxholdxx
6th Gear
Makes sense. I'll do it that way. What guage set do you use to monitor it?
also I'm not getting any knocks but I'm not sure what to monitor if it's retarding timing or not.
jt metal
08-14-2022 08:40 AM
harleycharlie1992
06-23-2014 03:54 PM
VETERAN75
08-25-2013 10:44 PM
DR. V-TWIN
12-13-2012 06:55 PM
Skippy97
05-11-2012 04:36 PM
