DYNOJET: Power Vision Target Tune
#161
#162
Lonewolf176 (06-12-2024)
#163
It doesn't like V Tune does, PV will pull timing if you go in the "auto tune" settings and allow it to, but they suggest only doing this with a wideband setup and AFTER your VE's are tuned, they also suggest not to let it make timing and VE changes at the same time, but what seems odd to me now is when you use the wide bands in "auto tune" AFR is set to 13.0 across the board. when I used to use the PV on the street I would log data after I had the VE's done and then graph the logs to check for spark knock
It does work very well once you get accustomed to it..
The other thing one needs to be careful of is that in each dialogue box on the win PV there is a checkbox up in the right hand corner whether or not you want to use the power vision as your guide or to use the stock ECM settings so you need to be careful there that that's enabled or disabled to however you want to use the system...
#164
Fat11Lo (06-12-2024)
#165
Not trying to knock your knowledge of tts nor the fact that I'm familiar with it but the OP is trying to figure out the PV.. And they do work a little differently.. I don't think info on tts is helpful to him..
#166
@Lonewolf176
#167
Yeah we'll Steve is not a fan of Power Vision, that's well known.. However I'm positive that it does have adapting learning and does change the VEs and puts them in a file all on its own to reuse. Even in the drop-down table you can go in and enAble or disable this function.. Here's a picture of adaptive control and read the paragraph down below which explains how it uses it how it stores it and how it works..
Also please define the broadband side on the ECM..
#168
To a large extent no, but theory of tuning an engine remains the same no matter which platform you're using, they both go about it differently. That's all I was tying to say to Lonewolf
Having never worked with Target Tune calibration, I'm not even begin to comment on the details
If I have anything to say to xxholdxx is that YOU MUST GET YOUR VE DIALED IN FIRST before you start messing with your other tables or you're going to run around in circles
When I used the wideband module with PV:
Run an "auto tune" session, while still on the "auto tune" screen I would take a picture to see where I got hits, then a pic of the next screen that tells you the changes,
and then apply the changes, save in a new slot, then flash the tune to the bike, ride the bike again without "auto tune" enabled and make a log of the ride
when I returned home I would retrieve the before and after tunes and the log and compare the two tunes in WinPV, to see how much "auto tune" made changes comparing the pic I took of the hits, also I would graph the log, if it made drastic changes in an area where I didn't get a lot of hits I would return those values to what they were before, it can be tricky, sometimes it make changes based on bad data, it's up to you to figure that out from riding the bike and viewing the logs
#169
@Fat11Lo
I'm theory yes it's I agree and should have stated that.. But for someone new to tuning it can be confusing is all I meant to say..I do understand @Lonewolf176 was only trying to help and that as well is appreciated, but info on 2 different systems can confuse a beginner.. Hell I'm still not where if like to be although I have made good ground on getting tuning down and will agree the VEs need to be set before you can start making any other changes..
Also I will have to take what @Steve Cole says about the WinPV software, I must have misunderstood Power Visions description of how it works.. The way I understood it was that the Win PV software makes a temporary file that stores the new short and long-term trims that the ECM and power vision refer to to keep the bike running As close as possible to target AFRs.. Steve definitely has more knowledge than I have in this matter so I will have to trust him .. Didn't mean to offend anybody or mislead anyone...
#170
Maybe think of it this way:
To use the “autotune” feature, or “v tune” or “smart tune” you need to start with a base map or calibration which is hopefully close to begin with so it won’t take too many test-riding (recording) to get right.
Once you find a base map by trial and error that provides a decent running bike without any tuning. This will be the “close” base map you want to start with.
Then you prepare the calibration or map for recording test-ride data from the on board sensors, especially the oxygen sensors.
Now it’s time to ride the bike in all areas it “could” be ridden in, NOT JUST THE EASY STUFF, especially at low rpms at higher loads where you would call it lugging but that’s where the bike needs to be put for a few seconds.
Once you’ve done your best at guessing where you needed to test-ride the bike to reliably record enough good data for the software to do its magic creating a new, updated/corrected map to be installed into the bike so you can repeat this process until you have learned enough to get enough data to complete your recalibration of your VEs as well as other tuning tables depending on experience and knowledge.
Then you’re done and, if you’ve been successful, your bike will run smooth as silk with snappy acceleration, all the while getting good mileage.
Bob
Bob
Fat11Lo (06-13-2024)
