THUNDERMAX: dyno tune + ThunderMax = maps, how?
I'm not an expert but have tuned a few builds on a dyno at a Beemer repair shop.. I mainly only to WOT tune to get an peak HP / TQ output.
The map has been typically run on the street for a bit and is whatever was closest to the build. I start by changing WOT timing to get best HP and then I override the AFR to one value and repeat trying to peak WOT HP adjusting the AFR globally. If it ends up being different than the AFRs in the tables, I reset the WOT setting in the tables..
At that point I declare it done as far as the Dyno goes and will tune the rest on the street as I have to pay for dyno time and I have a tendency to change things that change the tune.. If you can get plenty of dyno time, you can use the afr table and timing tables to peak performance at partial throttle positions..
One of the nice things about the Tmax is you can tune on the fly. Most flash program tuners require you stop and reload the map then test the results. On Tmax, you simple move the dot on the graph and the value changes in the module.. Steve Cole of TTS recently started allowing allow for changes on the fly but it only works on the later modules that have more free ram..
Again since I pay for dyno time, I just started to tune partial throttle on the street using Megalogviewer and collecting data. It's helped me pick up about 3 mpg and a little smoother running at lower speeds.
All you really need is the cable and a good laptop.. I'd also request the advanced user software licence from Thunderheart. It's free and unlocks the PC software to add some small features that are good. The important one is injector timing.. Others are the ability to have more than one map open at a time and a way to translate monitor data to ASCII text data to be read into mega log viewer.
What is useful is to use a laptop to monitor the motors perforance to see how the tune is doing afterwards.. Gen II systems are a little hokey on how it works but the Gen IIIs are much better. Throttle by wire or throttle by cable should not make any difference.
Tmax is a full time closed loop system so it pretty much auto optimizes AFR while riding with or without a laptop..
The advanced software is already in the program you have.. You only need to request a license from TH to get it..
Still not sure what you are trying to do.. I thought you were trying to tune a bike on a dyno with a Tmax..
No... The conditions I was describing was for tuning on a dyno.. You can change map parameters while the motor is running. That means you need a way to measure motor output (dyno) and access to the laptop while the motor is running.. I guess you could mound the laptop to your gas tank and play with parameters while riding but it'd be pretty dangerous.
It is so good that I didn't think the gains would justify the cash for the session
Then i was gonna skip scheduled session..
Then you say bout the unlock code..
TM support gave me the code..
One big purpose for it, they say, is so the software can be used in conjunction with a
dyno..
I do see some features that weren't there pre-unlocked.
Then i find that there's another code for advanced SmartLink but idk
What it does..
I was gonna try to build map from a dyno tuner till I found the magic map..
dyno..
What it does..
dyno..
What it does..
I saw in the other post where you found a map that works much better. That's good.. Like I wrote above the added features are not that much, the important ones were:
My mechanic, who sold me and installed TM, put me into the weeds several times before i decided he's not atall a tuner..
i only knew some of the components... map 862 is the best..
The rest of what you talked about... i don't know how to use.
would be great to know.
Thx
Thx
