The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
DYNOJET: Can I get a good tune if my clutch slips?
Old 05-10-2016 | 07:04 AM
beammeup's Avatar
beammeup
Default Can I get a good tune if my clutch slips?
I"m using Powervision with my newly installed HD 103 big bore kit and Wood performance 222 cams. It's a mild upgrade compared to many others for sure but I like what it's giving me. Clutch doesn't seem to slip to me, but what do I know? Answer is not much.
I want to have it dyno'd to get it running as good as it can and I keep hearing about the need to have a beefier clutch to prevent slipping. But I don't know if my clutch is slipping at all or within an acceptable amount.
So the question is: To what extent will a slipping clutch adversely effect the tune?
Sorry if this is a dumb *** question to those knowledgeable.
Old 05-10-2016 | 07:52 AM
jbarr1's Avatar
jbarr1
Why not just put in the screaming eagle spring or equivalent and not have to worry about it. It's very inexpensive.
Old 05-10-2016 | 09:15 AM
Mr. Wizard's Avatar
Mr. Wizard
If your stock clutch slips then you will have difficulty tuning your bike, yes... You can see it on a dyno sheet and sometimes you can just feel it as you ride aggressively shifting at high RPM's especially in the higher gears. The better the efficiency of your motor the more HP/TQ stress on your clutch.
The stock HD clutch will hold OK but only up to a certain HP/TQ depending on age/wear of your disc's. Some say 90HP/100TQ is all a stock clutch will hold. Just dropping a SE spring in won't guarantee a clutch will hold. It will guarantee that you will need Popeye forearms to squeeze the clutch lever.
Diaphragm clutch are much easier to upgrade than the newer style Slip-n-Assist three coil spring clutch that HD uses now. Since you have an 09 then there are many options to help build a nice bullet proof clutch.
I am pushing 100/114 on my 1200 pound trike. The stock clutch burned up at 4000 miles with some aggressive riding but mostly slipping the clutch trying to get that big trike rolling. After several attempts to do something here is what I ended up doing.
Maybe it will help you...
https://www.hdforums.com/forum/tri-g...-adjuster.html
Old 05-10-2016 | 09:43 AM
whittlebeast's Avatar
whittlebeast
95 pct of tuning is way below WOT. Personally, I would fix the clutch, if for no other reason, to not damage the clutch with heat.
A slipping clutch will kill any chance of getting any peak HP and Torque plots.
Andy
lee123
10-26-2019 09:39 AM
Firemn17
07-28-2016 07:16 PM
Firemn17
General Topics/Tech Tips
07-21-2016 01:25 PM
fxstc1999
07-01-2011 05:18 AM
2006ultra
04-12-2011 11:36 AM
Quick Reply: DYNOJET: Can I get a good tune if my clutch slips?
