The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
DYNOJET: Decel Pop - Dealership Can't Figure it Out -- Who Can?
Old 07-14-2015, 08:39 PM
writer1973's Avatar
writer1973
writer1973 is offline
Default Decel Pop - Dealership Can't Figure it Out -- Who Can?
I've read all the HD forums I can find about decel popping... most say a good tune will help. Not in my case. I picked up a 15 FXDWG four months ago and it's been back at the dealership 3 times already. They can't seem to fix it. Where do i go to find someone who can fix it?
Info: V&H big radius, Stage 1 download & supertuner. Pops like a machine gun every time i let off the accelerator. I'm at the point where I don't mind taking it to a better mechanic, but I don't know any better ones in the Houston area.
Thanks for any suggestions. I just want to enjoy my bike without people diving for cover.
Old 07-14-2015, 08:42 PM
QC's Avatar
QC
QC is offline
Received 19,803 Likes on 9,866 Posts
Baffles in the pipes?
Old 07-14-2015, 08:48 PM
writer1973's Avatar
writer1973
i haven't removed the baffles.
Old 07-14-2015, 08:50 PM
QC's Avatar
QC
QC is offline
I suggest a touch of fuel at throttle close. And maybe baffles with a bit more restriction in them, like the V&H quiet baffles, if made for those, I can't remember.
Old 07-14-2015, 08:57 PM
writer1973's Avatar
writer1973
forgive my ignorance, but what does "touch of fuel at throttle close" mean... give it more gas as i'm decelerating? it's a new bike, i shouldn't have to change the way i ride to make it sound normal, should i?
Old 07-14-2015, 09:08 PM
QC's Avatar
QC
QC is offline
I'm sorry. Have whoever is tuning the bike to make the supertuner add some fuel to the injectors when the throttle is closed. This should cools the exhaust just a bit and the added fuel will burn and not explode (decel pop) when it enters the hot exhaust pipes.
Old 07-14-2015, 09:16 PM
checkers's Avatar
checkers
checkers is offline
You have an exhaust leak or throttle is not fully closing. Pipes are not restrictive enough. You can try DK Custom "lollipops" to test with.
Old 07-14-2015, 09:35 PM
writer1973's Avatar
writer1973
thanks for the explanation... i'm not sure the mechanics at the dealership know what to do. they've tried it 3 times tuning it, no luck.. i have lot of friends who ride 103ci engine w/ aftermarket pipes, they have no problem with decel popping. i guess i just need to find a new mechanic.
Old 07-14-2015, 09:42 PM
writer1973's Avatar
writer1973
thanks for the tip... exhaust leak maybe around where they bolt up?
Old 07-14-2015, 09:44 PM
QC's Avatar
QC
QC is offline
As checkers said, also check all exhaust and intake fittings for tightness. A small leak in those areas will lean the mixture even more and contribute to the problem.
Quick Reply: DYNOJET: Decel Pop - Dealership Can't Figure it Out -- Who Can?
