Tire size
I run a 205/55-16 on the rear without any problem, 34PSI tire pressure, I ride 2 up all the time. you'll have 1/8" clearance on each side of the fender & belt. I get a better ride. better handling I wouldn't go back to a M/C tire again. the tire i'm using is a Michelin sport A/S plus. it's a bear to install but it's worth it. the tire cost me $125.00 and I installed, balanced it, then put ride-on in the tire 16oz. to stop flats & help balance the tire. If you have a H-D tire put on at the dealer you'll spend around 500.00 and only get 15000 or 20000 miles out of it.
Size
You can put up to a 205 55 16. You might consider a 195 60 16 though. The 195 60 will keep you a little closer to stock on the speedo. If you have a tuner like the Power Vision, that's not a consideration because you can calibrate your speedo.
I haven't tried a 195 yet, but I'm tempted to go that way next.
Quadracer posted a link to an article about how a larger contact patch doesn't equate to better traction, but it does equate to better tire life.
The reason you have better traction with a CT is it is softer rubber. The reason it lasts longer is the larger contact patch.
No Wider than 205 and no taller than 60. Every tire is different, there may be some 205s out there that will not fit. But, so far everyone I've heard of has fit. It should seat real easy, if you have to put 80lbs in it to get it to seat, don't use that tire. Keep max pressure in it until you get used to it, then decrease the pressure a couple pounds at a time until you find your sweet spot.
I don't know about better traction but the braking is allot better. When we start out in the morning the tire fells funny BUT after a mile or so the tire warms up a little it is great. right now when we leave for work it's about 45* but on the way home it's about 75 or 80*, nice time of the year to be riding.
