The Dark Side For those members running "Car Tires" on their scoots. This is for their discussion only and not a place for "non dark siders" to mouth off about their negative opinions of this idea!
size 2012 RK
Old 05-30-2015 | 10:30 PM
jrat69's Avatar
jrat69
Default size 2012 RK
Which size 195/60/16 or 195/55/16. Doesn't seem to be a big difference between them the 60 series is a little taller, and not quite as wide. Looking for the best fit for a 2012 RK ,lowered 2" in rear if that makes any difference.
Old 05-31-2015 | 11:31 AM
PFWiz's Avatar
PFWiz
Either will work, but the 60 will probably make your speedo a little more accurate. (all HD speedo are 2-3 mph optimistic at 65).
I am running a 205/55/16 Gmax on mine.
Old 06-02-2015 | 02:49 PM
tsigwing's Avatar
tsigwing
They're actually both the same width, 195 mm. I went with the 60 series to minimize the speedo difference.
Old 06-03-2015 | 08:25 PM
jrat69's Avatar
jrat69
Thanks for the replies, going to get it ordered.
Diesel-TFFT
07-12-2017 07:08 PM
misfitJason
04-05-2014 04:09 PM
cmosentine
08-07-2011 10:52 PM
kappyk66
01-04-2010 10:07 PM
CQCBlades
09-07-2009 10:31 AM
