2016/2013 Heritage Spoke Wheels
2016 Harley Davidson Heritage rear spoke rim and tire (OEM Dunlop 150/80/16)
I have a rear spoke wheel from a 2016 Heritage taken off with less than 200 miles with an oem Dunlop tire. Tire still has the tets still, the rim is in 9.5/10 condition I would say, with a couple pin size poc marks mostly around the valve stem, may even buff out. This is ready to install, no balancing, no need to change bearings. $275.00.
2013 Heritage Front Spoke Rim and 2016 Tire
Rim used, 20,000+ miles, 6.5-7/10 condition. Tire was from the 2016 and taken off before 200 miles on it. This set up you may want to change bearings, but does come with the rotor. $225.00
I may separate either set up, if I get interest for both rim and tire.
Located in the metro Detroit area if you’d like to pick up. All Rims are 16 x 3.
