S&S air cleaner fitment/ modification question.
Can an S&S air cleaner 17-0400 be modified to fit a 2011 XL1200X? The Correct S&S cleaner shows to be the 17-0448
The 17-0400 shows to fit the '66- '84 carbs. I know the efi doesn't have carbs but was thinking I could make a bracket that would make it fit.
I'm pretty sure that 2001 carbs through 2013 efi have the same bolt pattern.
The earlier carbs have a different pattern.
Something like this is what you would need.
http://www.jpcycles.com/product/404-416
I'm not exactly sure , but very much like it.
Then you have the head breather problem , different on the efi style.
I'm not sure it would be worth the trouble , the correct fitting unit does work well , I had one on my '09 Ultra Classic.
Call S&S , their tech support people are pretty good to deal with , I've used them before.
Mick
Mick
DLSSOJC
09-04-2014 04:54 PM
Banggood
General Topics/Tech Tips
05-29-2012 01:30 PM
