HD LED Daymaker issues
did you check all your fuses ??
The B1121 and B1122 are output faults on both turn signal circuits.
These can be caused by shorts to ground or when a LED or incandescent bulb fail.
did you do led lights all around ? did you pinch any wires ? check all the turn connections and the battery connections
other lights work ? runs? starts ?
Received 2,201 Likes
Wray67
08-28-2015 01:21 AM
Wray67
Electrical/Lighting/Alarm
08-27-2015 11:43 PM
