Using external breather system w/ SE AC 2004 Sportster
So I bought a used SE A/C on ebay that was on a 2002 Sportster. It has a K&N filter and a steel backplate. I own a 2004 Sportster with the stock CV carb and I wanted to vent the heads externally using a horseshoe breather kit. I followed MKL Sportster's guide on how to install but the banjo bolt heads prevent the backplate from seating on the carburator, even with the two offset "Z" brackets that are supposed to support the backplate. It seems the carb sits in too far in. My only option right now is to use the supplied breather bolts that hold the backplate to the heads, but vent the crankcase gases internally as designed.
Do I need one of those support brackets that everyone uses to mount an aftermarket AC and/or should I use breather bolts like the ones DK Customs offers? Should I just live with it and vent the heads internally like lots of other people do? Is there a spacer I can buy to get the backplate to sit far enough out to use the horseshoe style breather kit I have?
Hopefully someone has done this or can help me. Thanks in Advance
I bought a carb support bracket from Hammer Performance. The z clips, as you noticed, are not sufficient. No issues with clearance here.
With the bracket on supporting the carb I just out a couple short bolts with gaskets on to block off the old holes in the backplate.
I know the '04+ back plates have that plastic that sticks out for the breather standoffs. You need to cut those off or use a different back plate.
You wouldn't happen to have any pictures of that would you? I wonder if the carb support bracket will be thick enough to give me the clearance I need. For right now I used the supplied breather bolts that go through the backplate and uses spacers between the backplate and cylinder heads. I want to use the chrome horseshoe breather but those z brackets don't allow the backing plate to even touch the surface of the carb opening.
Not of mine. I'm no where near my bike for this week.
I ditched the z-brackets all together and just used the support bracket. The z brackets I looked at didn't really seem like they would fit all that well, and it sounds like I made the right choice.
http://hammerperf.com/images/blackcarbbracket.jpg
That is the support bracket I used. Without the z brackets and that bracket the carb is supported and there are no clearance issues with the backplate. The bracket is about the thickness of 18ga steel.
I'm not sure what plastic ring you're talking about.
In other words, does the backing plate mount right to the carb bracket or was there a spacer between the bracket and backing plate? I know you said you are nowhere near your bike but if you remember. Unfortunately neither am I so I can't take pictures to show you what I am talking about.
I have the flat steel backplate SE AC on my 1991. It looks like if you just replaced the hollow bolts with some that were only halfway hollow with side drilled openings, you could just replace the spacer with Banjos of the appropriate diameter and length. I've been thinking about that myself, just have not seen a kit that does this. Is that something that would work??
John
John
There's a velocity stack shaped ring that I know goes on the inside of the backing plate, but there is another plastic ring that looks like a spacer for lack of a better term.
In this picture here where those empty holes are were the old breather bolts. That is now plugged with a short bolt and nut. The support bracket just sits in there between the carb and backplate, nothing else changed.
Figured it out....
My order goes from the engine: intake manifold->manifold seal (round rubber thing)->carb->gasket->support bracket->gasket->backing plate->plastic velocity ring thing.
The CV performance deluxe tuners kit, a bunch of carb cleaner and clean lint free rags, the external breathing kit and the Screamin Eagle air cleaner really woke the bike up. I used the suggested 44 pilot and 175 main jet (there was a 42/160) and im out two turns on the EZ-adjust screw. I'm getting my Cycle Shack turnout mufflers in the mail on thursday, I think this combination should work out pretty well.
Thanks for all the replies and advice, I just needed to walk away from it for a day and do a little more research and with everyone's help and a little common sense I figured it out. I like the older ham can on my bike because it's a little smaller and it has the good metal back plate and a proper K&N filter in it.
Next up is a set of new wires and one of those Dynatek single fire ignitions for the 2004-2006 Sportster......
BIGDADI
04-25-2009 09:12 PM
