Home made Trailer
Home made Trailer
I have a fold up trailer capacity approximately 900lbs, sometimes it would be nice to have the capability to haul the Sporty in the event of a break down or weather realated issue.
Does anyone have a foldup converted to haul there bike and some pictures ot post.
I have a 3/4 inch greenwood deck on mine a few tie downs, I would make a ramp out of re-inforced plywood as I feel a rail is to dangerous to ride up on.
I am concerend that the trailer is to flimsy tho, any thoughts?
Thanks
Tom
http://usera.imagecave.com/TomF/TongueRedTrailers.jpg
http://usera.imagecave.com/TomF/850TA.jpg
Thanks
Tom
RE: Home made Trailer
ORIGINAL: thomasf59
Thanks
Tom
Thanks
Tom
I've had a fold up Harbour Freight Trailer for about 6 years now. Cost $400. Capacity 1000lbs. I've towed sportbikes, dual dirt bikes, and friends have borrowed it to haul big twins, ie: Fat Boy, Road King Classic. All with no problems and no drauma. Take good care of the trailer, set it up properly for towing, re-check and double check everything for safety and you should be good to go.
NightsterHooligan.
Are you useing a wheel chock, and can you post some pics of the trailer when you have your camera out if you think of it and if you have a camera. I have the 4.80 X8 wheels and tires on mine, be nice if they were 12in.
I have a wire feed welder and have thought about beefing up the frame on the trailer, maybe boxing the 14 ga. C channel for some added strenght.
Most likely if I do make the mods to haul the bike I won't use it,( thats the way it goes) I need to have the bike serviced 1 k, dealer threw it in, in the deal, but theweather is lousy 17 degs, some snow, and if I was set up to haul it I would of.
What are you useing for a ramp? What material did you use for the decking?
Thanks
Tom
Thanks
Tom
HeyThomas, I'll post some pics when you post some more pics of the chick in your avatar! LOL
Yes, I have 2 Pingle wheel chocks, one centered for carrying a single bike, and another small one off the left side for when I tow the 2 dirt bikes. It has 12 inch tires, 4 bolt lug pattern. Used 3/4 inch heavy plywood, with a heavy duty epoxy paint, similar to the stuff you put on your garage floors. I use a 2 x 10 pressure treated board with a metal ramp tip attached to the end. The trailer is real low in the back so there isn't much of an angle to get the bike up. I have a spare tire attached to the tongue of the trailer. Other than that it's a stock trailer you can pick up from harbour freight. When folded up one person can lower the trailer down, but it takes two people to lift it up. Rolls around on caster wheels. Takes up 2' x 5' of garage space. Great trailer if you are on a budget or dont have a lot of storage space. Tows great on the highway, nice and stable, you don;t even realize it is behind you at times. A little tricky to back up because it's so low, you really can't see it. This would also depend on the tow vehicle. It's folded up now, so the next time I take it out, I'll take some pics.
Wow, I just looked online and the trailer itself is just $249, just add the decking and chocks and you are good to go.
http://www.harborfreight.com/cpi/cta...emnumber=90154
