Stopping brake light from lighting up
08-02-2014, 03:24 PM
I want to only have the brake light to light up when I push my rear brake and not have it light up when squeezing front lever. Is there any way to do this?
08-02-2014, 03:42 PM
Disconnect the front switch.............but why?
08-02-2014, 03:55 PM
so the guys he is riding with will not know how much brake and how often he is grabbing it...not cool to use the brake too much.
08-02-2014, 08:39 PM
Quote:
Originally Posted by
sorensentyler
Da f×+k?
08-02-2014, 08:54 PM
If its like the tourers, there is a plastic button on the brake lever that breaks real easy when you replace the levers, just break it off.
But yeah, why?
08-02-2014, 08:59 PM
You need to use a special single filament bulb, ask the dealer for a rear filament bulb.
Reason: Spelling
08-03-2014, 06:12 AM
Dan89FLSTC
You need to use a special single filament bulb, as the dealer for a rear filament bulb.
er...no
then the brake light won't come on at all.
OP still wants brake lights when he jumps on the rear brake.
08-03-2014, 06:24 AM
Quote:
er...no
You`re killin me...
Right over your head...
08-03-2014, 06:33 AM
Disconnect/remove the front switch...Easy.
I used to always disconnect the switch on the front brake, there are some pretty good reasons to not want a brake light under certain conditions.
08-03-2014, 06:52 AM
Greezey Rider
Do Tell...Im all ears.....
