Exhaust Help!
I think the short shots are played out too.
Last year I put on the SE Street Performance slip-ons. Wasn't all that excited about the sound, but an article I read showed they dyno'd better than V&H. This summer after reading around the interwebs, I went with the Thunder Torque Inserts from DK. I removed my baffles and installed these.
The sound is definitely there now, and the performance seems to be the same if not a little bit more. I am pretty happy with them. I rode with two friends that each have V&H Short Shots, one with an 883 the other a 1200, and my Iron is louder.
Just my $0.2. Of course performance wise, 2 into 1 is the way to go.
Received 4,205 Likes
Loud is in the ear of the listener.
Take a listen to my Sporty with some 2-1 exhaust that was made from our Exhaust Builders Kit.
Here's a pic of the pipes from the above video...they are wrapped, but if you wanted them all black, just don't wrap them.
Short Shots are popular for a reason, they look good to a lot of people and a lot like their sound. Downside is a bit of a loss of low and mid range power.
This is easily taken care of by adding Thunder Torque Inserts to them. Not only do the TTI's give a good bump in the low and mid range, they also deepen the tone of the exhaust a little. You can check them out HERE...there are some dyno charts also.
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
You do not "need" to do anything when installing slip-ons, IF you are happy with the performance of the bike.
It will run better if you spend around $100 on some XL-ViED-14's to richen up the mixture. See details on it HERE
It will run even better if you spend around $500 on a Power Vision Package with Auto-Tune. See details of it HERE
There are other tuners that are more than $100 & less than $500 that will provide improvement. You can see an overview of the popular ones at the following thread-
https://www.hdforums.com/forum/ignit...uning-etc.html
To be clear, you will not damage your bike if you do nothing other than add slip-ons...everything else listed above is only if you want a smoother, cooler, stronger running bike, AND if it's worth it to you to spend $ to accomplish it.
