Oil Coming Up Clutch Cable?
Old 07-22-2014, 07:05 AM
GMRO's Avatar
GMRO
GMRO is offline
Originally Posted by Von_Zipper
I had same leak ... gearbox vent was clogged by some bug which built a nest and laid eggs there.
Thank you to all! Guy rode bike to work and wife texts me that he's happy...no more leaks. Musta been the clogged vent line.
This board is great, appreciate all the help and advise.
Old 11-22-2015, 10:56 AM
jorgesporty's Avatar
jorgesporty
jorgesporty is offline
Stage I
Post
"So no way to check the level? There is an inspection cover has 2 bolts on the chrome trans case above and left of the diag/pic posted above with the numbers? That where you fill it? Remove the small screws - 2 - and remove the small metal inspection cover?"
That cover is where so you can adjust the chain. Most places say "1/2 of play. You can fill from there, but most recommend through the derby cover so that you can see the level of the oil. But if it's empty 1 quart should do the trick.
Charles Bryant
07-20-2018 09:09 PM
skirtbum
06-26-2010 05:45 PM
crewzerdude
04-27-2010 09:18 AM
YellowHawk
12-16-2007 05:40 PM
LOOPNERS
10-14-2007 10:22 PM
Quick Reply: Oil Coming Up Clutch Cable?
