I think my rear brake is stuck 'on'..adjust?
Old 07-11-2014 | 11:19 PM
HighestHD883's Avatar
HighestHD883
Default I think my rear brake is stuck 'on'..adjust?
Started hearing a weird sound... Rear disc is way hot compared to front and seems like the pads are touching the disc as it sits here. Can I do anything to fix this? Adjust it? I was planning on a 4hr ride tomo and 4hr back on Sunday.
Old 07-11-2014 | 11:51 PM
Von_Zipper's Avatar
Von_Zipper
Brake caliper grease.
Old 07-12-2014 | 12:02 AM
heybaylor's Avatar
heybaylor
take the calipers apart. check replace/fix before bad things happen
Old 07-12-2014 | 12:08 AM
Uncle Chester's Avatar
Uncle Chester
Seen it happen a few times. I'd always just get a caliper rebuild kit and flush the brake fluid. They can do some serious damage when they hang up like that.
Old 07-12-2014 | 12:13 AM
HighestHD883
fack.. what does something like this cost? it may be out of my range of abilities, but i mean i'd give it a try - intense thing to mess with, i think
on the front, I can see a little gap one side, but not the other. on the back, it looks like both are just touching the disc. I can mostly hear the sound when going downhill and the engine is less loud, with no brakes on.
would they have been like this for awhile or is this a sudden thing?
oh one more thing then... can i upgrade any parts for better braking?? (that wont break the bank)
Old 07-12-2014 | 12:20 AM
Uncle Chester
It's pretty straight forward. Just get a service manual and brake fluid, the few times I done it I rebuilt the calipers as well but it is probably not necessary. If you pay to have it done I wouldn't imagine it would be to much, especially if you go to a indy.
Old 07-12-2014 | 12:26 AM
HighestHD883
yes sir.
I believe I can tackle this. From what I've read everywhere on the forums, I should start by bleeding them and go from there. There seems to be a decent amount of pad left, so hopefully this will fix it.
any recommendations for brake fluid (DOT 5, Silicone-based)?
bike is an 01 883
any pro tips welcome!
Old 07-12-2014 | 12:29 AM
HighestHD883
also, is it worth flushing the system, since I dont really even know what kind of fluid is in there now?
Old 07-12-2014 | 12:35 AM
Uncle Chester
Yeah you want to flush it. Especially if you don't know the last time it was flushed. I got a 02 sporty and it takes dot 5 so I imagine your 01 is the same but the service manual will tell you for sure.
Old 07-12-2014 | 01:07 AM
HighestHD883
ya, its DOT 5.
I will take a picture either in a bit if i step outside or in the morning of the front and rear pads - IF they need replacing, is there any caliper/system upgrade i could/should do, or just replace the pads?
is it worth getting a vaccuum bleeder (or using a big syringe and a hose? i'll be doing this solo.
also, what could you recommend for brake cleaner?
