Engine cut out
Engine cut out
I have yet another problem. When do I become a certified harley mechanic btw? Whit has much as I have fixed got be close.
89sportster just rebuilt carb after it was flooding.
Now while riding at normal throttle and different speeds the engine cuts out.
The float is adjusted perfectly it couldn't get any better. There is a new fuel line as of last year and a new fuel inlet as of last year. There is not black smoke or black coming out the pipes and it doesn't smell rich.
Wondering if I'm too lean or if it's something else.
It will also cut out at file and it only cuts off when it's warm (the engine not like outside). The wires to the bank switch are all fine and they are free from trapping. This happened before I replaced the regulator but even then the regulator and all the circuits are fine and intact and not making any contact they shouldn't.
I have new wires and spark plugs. Gapped so perfectly that harley would cry.
Coil is newer and in good shape from appearance but don't know how to test it.
Engine will just dead stop but has no problem starting right back up. Wtf???????
Dechicco
11
12-03-2019 07:23 AM
