Please advice -- Max speed is decreasing
Hi,
I am on a road trip from Seattle to Chicago. My bike started to have issues this morning (day 3): I can't ride faster than 65 mph anymore, 55 mph uphill. I can hear the rpms shoot sky-high without any speed gain (doesn't matter which gear I am in) if I turn the throttle too fast or at a certain point. My oil is pretty low (no signal yet) and I haven't changed the oil filter for a while. I also got stuck in a bit of mud on my way to the campground and had to turn the throttle a bit harder to get out of it the day before. Any ideas because I would love to avoid getting stuck in this town here. Thanks a lot!
Hi,
IMO, That can only be a slipping clutch. They may just need an adjustment. But if you've been slipping them for too long, the plates could be worn to the point of needing to be replaced. An adjustment, even at a dealer, should be as quick, cheap & easy as my Xwife.
There is no oil level warning signal on these bikes. There's a low oil pressure warning signal, but if that comes on you need to stop riding immediately because you're risking damage to the engine from a lack of oil pressure.
