Primary chain jerking
I have a 1988 883 with less then 6k miles on it. I've been noticing lately when I roll on the throttle to go there's a slight jerk from my primary chain. It's not a hard bump but it's noticeable. I changed my primary oil a couple months ago and checked the free play in the chain and it seemed ok. Any other ideas or should I adjust the chain again.
I would check the chain again and remember the measurement should be taken at the tightest spot in the chain. If you don't find the tightest spot you will still have a loose chain after you are finished. I personally put my bike on a lift, get the back tire off the ground, remove the spark plugs, put it in 5th gear and rotate the rear wheel by hand checking the chain play in many places until I find the tightest spot. This is where I do my adjustment.
Received 2,201 Likes
http://xlforum.net/vbportal/forums/s...ad.php?t=10084
Third or 4th post down. This is where I found out about this method.
