Anyone drill out 2014 stock exhausts eyt?
Old 06-15-2014 | 04:36 PM
1HDRIO's Avatar
1HDRIO
Default Anyone drill out 2014 stock exhausts eyt?
Ok...so i have not yet decided on an exhaust yet, but I want to try and debaffle my stock mufflers and add the DKcustoms TTI's.
Has anyone tried this yet with the 2014 mufflers? Is it catted?
Thanks!
Old 06-15-2014 | 07:21 PM
Captainruss's Avatar
Captainruss
I did it on my '14 48. Sounds better and the TTI's give the torque back that you lost by drilling out the cap.
Old 06-15-2014 | 08:59 PM
1HDRIO's Avatar
1HDRIO
Thanks man...was it just the cap that you removed or the whole baffling to make it an empty pipe?
Old 06-16-2014 | 06:54 AM
okiesho's Avatar
okiesho
You can't remove the baffle without cutting the whole muffler in half to gut it. There's a catalytic converter in each muffler attached to the baffle. That makes the baffle pretty impossible to pull out.
Old 06-16-2014 | 06:59 AM
Andy Knell's Avatar
Andy Knell
I drilled mine out a couple of weeks ago too. Just the cap at the end of the baffle with a 1 1/8" hole saw (bit) from Lowe's. BTW, couldn't get a 1 1/4" bit to fit.
The '14 exhaust is catted but there's plenty of room between the cap and the cat. Just be careful when the drill punches through so you don't slam the cat. I thought about taking the cat out too but it sounds good enough with the cap gone.
Old 06-16-2014 | 03:12 PM
1HDRIO's Avatar
1HDRIO
Cool thanks I should be trying this during the weekend...
Old 08-01-2016 | 09:20 PM
newtothe48's Avatar
newtothe48
I drilled multiple holes in mine (only had a 5/16" long bit) about 5/6 holes, best I remember and it does have a good sound. Not low like some after market systems but louder without being too loud and just sounds much better!
Old 08-05-2016 | 09:48 AM
4lss's Avatar
4lss
6th Gear
Hey all,
Is there any tutorial on doing this mod?
Old 08-05-2016 | 03:39 PM
newtothe48's Avatar
newtothe48
Never seen one, but very simple.
Old 08-05-2016 | 11:33 PM
garyalan7's Avatar
garyalan7
So I did this on my '16 48, you can pick up a cheap 3/4" step drill bit and 12" extension from harbor freight for less than $20. Works perfectly. I started small and worked my way up to 3/4". Definitely got louder and deeper, I could finally hear the bike at speed, however it was not loud enough for me so I bought a 1-1/4" hole saw bit to remove the entire baffle. IMMEDIATELY REGRETTED IT. Yes it got louder but it changed the tone entirely and doesn't have a typical Harley sound, it's strange, I don't even know how to describe it. And the decel popping is RIDICULOUS. I personally would not go above 3/4" holes in the baffles if I had to do it again.
I had to go to home depot to find something to kinda close it off real quick like, so I picked up these 5/8" brass flare nuts - drilled and tapped then installed in the mufflers and it got it back close to where it was with roughly allowing 3/4" airflow. Even with loctite and lock washers they vibrated out. So I had to remove the heat shields and drill it from the side, completely through both sides the muffler with longer screws...and anyways...
Lots of trouble I went through lol.. but I cannot recommend enough to not go too big. A 3/4" hole sounds GREAT until you can get something better.
Quick Reply: Anyone drill out 2014 stock exhausts eyt?
