I had to charge my battery the other day. put battery cover on, went for a ride and the cover popped off except for the bottom metal hook.
The only thing, as you probably know, that's holding this on is that hook on the bottom and two plastic nubs on the top part.
Is there a better way to secure the battery cover to the bike?
Seems like these nubs will wear down after only a couple battery changes/charges.
You didn't state what year your sporty is but on my 2006 they have updated plastic clips now. They are still cheep, but mine never came off after I upgraded to the newer ones.
Create a slit in the plastic clip. Securing the zip-tie is not required. With this arrangement, and a little patience, I could remove and re-install the same zip-tie with the seat attached. It helps to leave a little of the zip-tie sticking out, as shown. I only used one tie, on the front clip.
2004 1200C:
Reason: nunya
