Sporty leaking a bit of oil..first time! help
It is the lower gasket between the head and the lower rocker box - the manual confuses me a bit because it goes way deeper than what I believe I have to do here.
so to put in TDC, i have to get it into 5th gear (roll back and forth till i get it to 5th) then can i just push it a metre or two until i get it to TDC w valves closed? i am going to be doing this on the side of the street so i dont have a lift, etc.
so let me see if I have this correct:
*Remove Ignition Coil, then..
1) Loosen/Remove 4 bolts on upper rocker box cover
2) Remove Upper Rocker Box Cover and then gasket(s)
3) Remove Middle Rocker Box Cover and then gasket(s)
4) Put front cylinder at TDC w/ both valves closed
5) Loosen/Remove 6 bolts holding Lower RB Cover to top of head
6) Remove Lower Rocker Box Cover and then gasket(s)
7) Clean all surfaces and rid of any old gasket material
8) Replace Lower Rocker Box Cover gasket(s) and work my way back up
*I plan to take a bunch of photos for my own sake, at every stage. I have a needle torque wrench so hopefully that is all good, I know how to read it so it should be alright - i will take to HD when im done and maybe just have them check it/re-torque it for me
I've got 1.5hrs till HD opens so the more I can get figured out now, the better. Cheers
Ya I hear ya! I'm just renting a room from someone and I don't want them to get pissed off because there are oil spots all over their yard ha ha
here's what I picked up from HD.. I think that is everything I need! If not, well im ****ed once I start tearing it apart because I have no other mode of transportation to get back to HD.
HD883, check this site out for parts info & good luck.
http://www.shopronniesharleydavidson...partfinder.htm
Well boys,
just like that.. saved myself $260! Wouldn't have happened without the wicked *** people on this forum (and my manual - which pictures, but never mentions the 3 bolts in the bottom of the inner rocker arm cover LOL.. ya that one had me scratching my head for a bit)
but hey bike is running great and sounds great.. thanks guys!
