S&S slip ons Loss of torque
Here is a LINK to the thunder torque inserts that the above are talking about. These will give you a little boost in low and mid range torque.
Below is a Dyno Chart so that you can see the results yourself...
__________________
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
www.DKCustom.com
662-252-8828 Voice
Your engine is now lacking back pressure which it needs, either torque cones or the DK Customs inserts are to restore the back pressure to your engine, neither are very expensive.
The DK customs insert goes in without having to remove the pipes, the torque cones would require dropping the exhaust and putting them in at the exhaust port.
SoCalSoftailSlim
01-18-2013 04:07 PM
gpp
11-16-2012 03:03 PM
