Module turn signal blinker brake light unit
Hello members
i think i have a faulty led signal module, i have joker rear led signal and blinkers in tail section and the left side work fine, however the right side is acting up,
when i start the bike the right side comes on and stays on as it should since it acts as a taillight, when i press the right side signal the leds blink as they should but at a faster rate then the left side does. when i turn off the right side blinker, blinker shuts off but he tail light does not come on.
the only way to get the tail light on i have to shut the bike off and on again.
so i think its the module that is faulty cause if if switch the wiring for left and right the same behavior is present on the left side...
my question is there a fix i can do my self since the module is nothing but a relay, the dealer in canada wants $169 for it and i think that just hwy rubbery.
if you have a solution and could share it it will be great.
my bike is 2009 sportster iron, the module part # is 68278-07
I have just been reading about a similar problem on the forum but cant find it now, its the module. You can a get a cheaper one from Badlands, thats what I just read, hope that helps.
sorry duplicated
contact Bryan from jokermachine.com and get the Badlands LED Intensifier Converter, his very helpful and super nice guy, it good to know that some shops in usa still value customers from canada and abroad.... this fixed my issue with the led signal for the rear.
http://jokermachine.com/products/har...converter.html
mshred
Electrical/Lighting/Alarm
01-28-2018 07:36 AM
koresample
02-09-2015 10:38 PM
car5car
11-27-2009 08:00 AM
