What's a good alternative to the OEM ignition switch?
My ignition switch on my '07 is going on the fritz. I have ti wiggle it to get the fuel pump to click over. So I need a new one. The retail for an OEM HD switch is $75! I've seen switches for $25.
I do not want to relocate the switch and coil. Is there an alternative or aftermarket switch that will work on the stock bracket in the stock location so I don't have to do any modifications or relocate the switch?
Thanks
Thanks
Anyway, I guess we all have our priorities and if you are confident of your mechanical ability go for it.
I just noticed that you are a veteran of the Submarine Service. My guess is that you could make a new switch with an empty Pepsi can and six inches of electrical tape. Sorry about questioning your mechanical ability and I thank you for your service.
"He Who Lives In Joy Does His Creator's Will".
The Baal Shem Tov, Founder of Chasidic Judaism... ca. 1750's
How about to save you the time and effort of fabricating a housing to accept the new $60.00 Key Switch. Frankly, 35 dollars sounds cheap to me concerning the potential time and aggravation involved. But hay, that's just me. It could easily cost much more then $35.00 to have a mechanic install a cheaper non-HD switch.
I suppose I'm handy enough but don't want to jury rig something that would look half-assed.
Location: In the foothills of southwestern NC - US of A
I never had one out and in my hand, but does the switch look the least bit serviceable?
Case in point...years ago I was handed down a '68 Pontiac, and after a few months the ignition switch was crapping out. I went everywhere looking for one, even the original manufacturer, and it was a no-go. And this wasn't the typical ignition switch; there were 5, 6, or more contacts in the damn thing ['can't remember, it's been many years], and with nothing to lose I twisted the pot metal tabs away from the plastic housing it was attached to and it came apart. After a quick look inside I found the problem...there was a semi circular contact with three raised **** on it that was under spring pressure, but the springs had lost their sprang and the contact had lost a number of it's **** [they were worn flat like a Mom's ***** after breast feeding three kids, LOL]. So I gently re tit'd the raised contacts with a small drift pin/block of wood, and made new springs out of those you'd find in a ball point pen, put it back together, and voila', va-freakin'-room!
So if it's able to be disassembled do so and see if you can surmise the problem, and hopefully you can fix/repair it; if not, oh well...we gotz to shell out a few sheckles every once in a while to git 'er done right.
=8^)
=8^)
