1200L Air Cleaner
1200L Air Cleaner
Doing a stage one this weekend,, the dealer tells me that they use my old cover (the ham can) lol..... Question! does any know of another type of a/c that I could get to replace the factory installed air cleaner
This is all new to me, the dealer said that there may be some "aftermarket thing that I can through on"
Thanks all
D/C
Thanks all
D/C
RE: 1200L Air Cleaner
i'm not sure if you have an 06, with a carb....or 07 with an EFI.....because their isn't a lot to choose from yet for an07,EFI Sportster.....
But you can see the few in aftermarket catalogs like Drag Specialties(hense-The Fat Book)....or Dennis kirk.....or J&P Cycles....those are the big 3 aftermarket companies.....
thats about all the info that i have....i'm alsoin the market for an aftermarket A/C.....
ORIGINAL: bikecop40
Thanks all
D/C
Thanks all
D/C
Yes ther is a lot of ac out there the on that the Harley shops uses is SE and they use the same front housing and replaces the back plat on the ac but if you do a serch on ebay or the web you can fine a lot out there like this one here http://cgi.ebay.com/ebaymotors/Smoot...08623901QQrdZ1and like every one elce said look around you can fine one that you will like
Sorry, it's an 06 1200L, I have the pipes( Drag Specialties) I installed them last year, the bike has 2500mi on it and would have left it as is however, I was told that I may be running it too lean, so before the riding season gets under way I decided to play it safe with the stage one
D/C
D/C
