Timken part# for HD wheel bearing part# 9247
I didn't have any luck at our local bearing supply, even after I took the old bearing in for measurements. The guy looked in some books and got on the phone, came back and said it was exclusive to HD. The cost from HD was pretty much in line with the local supplier's price on bearings of similar size, so I didn't feel so bad about it. Other than the 50 mile trip to the dealer.
Sarah
Sarah
I'm replacing front & Rear bearings on a 2005 Ultra Classic
Here's what I found...
HD Part# 9247: 1" (25.4mm) Bore x 21mm Thickness x 52mm Outer Diameter
(w/ ABS Brakes: 1" (25.4mm) Bore x 15mm Thickness x 52mm Outer Diameter) to compensate for ABS Sensors
Radial Ball Bearing | Double Sealed
Enduro Bearings offer a compatible bearing (DH559486) but I've read mostly bad reviews about their products, so BUYER BEWARE!
https://www.hendersonbearings.co.uk/...bore-9247.html
Notice in the description: "In the very unlikely event that we should not have available free stock in the listed brand, then a quality brand will be supplied." (define quality)
Motion Industries offer a compatible bearing (Mi Item #: 00052605) but looks like it's only available for ABS model bikes. (15mm wide vs. 21mm wide)
https://www.motionindustries.com/pro...p?sku=00052605
Grainger offers a compatible bearing (44Z821) but looks like it's only available for ABS model bikes also. (15mm wide vs. 21mm wide)
https://www.grainger.com/product/TIM...Bearing-44Z821
It's on Amazon as well, but again, it ooks like it's only available for ABS model bikes also. (15mm wide vs. 21mm wide)
No ABS here, so HD#9247 (1" Bore x 21mm Thickness x 52mm Outer Diameter) still the best bet unless you have ABS...
"New Member / Old Thread Resurrection" got me and I'm usually pretty conscious of that ... (but I know how it got me )
But anyways since I'm here because of the following post ...
Just get the OE #9247 bearings and be done with it ... They're good
WKNDS (05-13-2020)
