Synthetic Oil vs. Regular Oil
I am taking my 2006 1200 Roadster in for my 1,000 mile check-up and I am going back and forth on synthetic vs. regular oil. From what I hear on the forum now (1,000 maintenance) is the time to switch.
Is it worth switching to synthetic motor oil or should I stay with the regular stuff ? What are the benefits of synthetic ? I know it will cost me more and I've read on the forum that once I switch I can't (or shouldn't) go back to regular oil.I don’t have a problem with switching if its better for my Sporty in the long run.
RE: Synthetic Oil vs. Regular Oil
I don't think you can go wrong withsyn. oil. On top of getting the added duability against premature breakdown of the oil molicules, your motor will run cooler with syn. I do prefer a true synthetic oil, (amsoil, royal purple,Mobil1, etc.) instead of the semi synthetics made from dino, like HD's syn.
I use mobil 1 fully synthetic, bike runs on average about 10-15 degrees cooler, and engine noise has also been quite a bit quieter. I'm gonna switch back to some dino oil now though, I just finished my 1250 conversion and need to break the engine in. But as soon as I'm broken in again, i'll be back on the mobil 1 synth.
ORIGINAL: bikecop40
If you change your oil @ 2500-3000mi, syn is a waste of money
ORIGINAL: Zattaltin
Sorry about the newbie question but its about 5000 per change on these things right?
Sythetic is the way I'll be going as soon as I turn 1000
