Code p0563
Code p0563
So about a week or so ago my Check engine Light would periodically come on. I looked at the codes and it threw a P0563, over charging. Look at this forum and people suggested maybe bad battery or connection or the voltage regulator. So, battery is about 2 1/2 years old and not a problem. Connections are tight and clean. So I ordered a new voltage regulator and changed it out yesterday. today light cam back on after about 10 minutes driving and stays on now unless I am at an idle. Any rev hight than an idle it is on for good. Threw the same code. So, If it something else you think or since it is always on now maybe the regulator I purchased from JP Cycles is bad? Basics, 2004 XL883. Also, will I damage anything if I ride it home with the light on?
Thanks.
Thanks.
