How do you crank motor without starting?
04-28-2014, 03:38 PM
Im about to do some work on my shovelhead, but I assume the process is the same. Im gonna take off the cylinder heads and maybe the entire engine. But in the service manual, it says to crank the motor until the cylinders are closed. How do you do that when the batter is disconnected?
04-28-2014, 03:44 PM
Hand turn the rear tire while in gear.
...Assuming rear tire if off the ground or on a lift or some soft.
04-28-2014, 03:51 PM
04-28-2014, 04:50 PM
Quote:
Originally Posted by
jcallesano
+1 - And in the highest gear and the spark plugs removed.
04-28-2014, 06:58 PM
brad75raiders
Engine Mechanical Topics
01-18-2017 10:03 AM
biginchhustler
Shovelhead
01-03-2014 10:16 PM
biginchhustler
Shovelhead
06-19-2012 12:31 PM
Flint
08-06-2011 06:51 PM
Mr1986FLST
EVO
21
12-11-2009 01:38 PM
