what bolt is this?(pics)
thanks alot man. Would this one work? or is the thread size to big? how about the metal used or if it's grade 8 does it even matter?
http://monsterfastener.com/itemview....FWZo7AodRRIArA
That'll work.
Grade 8 and the thread pitch is 14 per inch. Should be good. Don't forget the lock washer. There's probably a torque spec for that bolt, since it threads into the head. You don't want to strip it.
If the threads are already boogered in the head, you have an additional issue. They're probably ok, but you might want to clean a little oil off of there and give 'em a look-see.
