Front Turn Signal Relocation
I just bought a 2014 48 all black Sportster and love it. So far I have the stage 1 download, new air cleaner, and put drag bars on it. I ran into some clearance issues with the drag bar hitting the tops of the forks but found some great advice on this site on how to fix that.
I also have some clearance issues with the turn signals and need to relocate them down to the lower bracket screws on the triple tree. Does anyone have any advice on the best way to do this? If not, how about some advice on good looking aftermarket alternatives. Thanks for any help you can provide.
Clicky
I bought some fork clamps off of ebay which work pretty good. I mounted them under the triple tree. I would have like to mount them above the lower fork bar.
The thing I was wondering is how do you get the turn signals through where the speedo and headlight are so the wires run behind them? Do you just have to take them off? I took off the speedo, but couldn't get the headlight brow bolts off so I just mounted them to up higher for now.
These are the clamps I bought, seem to be ok but would love to get the turn signal to hug the forks a little more. It should be a simple as getting a shorter screw and using a rubber washer instead of a spacer right?
http://www.ebay.com/itm/161219640366...84.m1423.l2649
Also love how 128autos look
wiggum
01-26-2015 04:10 PM
