seafoam in the oil
Just my 2cents worth but I wouldn't . I'd be afraid of it causing a gasket problem or something. I think it has some of the same solvents used in paint thinner in it that may not play well with gaskets when hot. Some folks swear by it for fuel problems but that's a different temperature range.
And if you're running a quality oil to begin with, there's no sludge in the motor that needs cleaning out anyway.
Take apart any high mileage car or motorcycle engine that has been properly cared for, I bet you will be amazed at how clean they are inside.
You don`t need to add anything to the oil, no matter how old the vehicle is.
Leave it to the chemists and engineers at the oil company to blend the oil for you, they know what they are doing.
Hey cHarley yeah i run mobil 1 15/50 so i guess im good ill just do my oil change as usual and all should be well . thanks everyone for the input.
Hmmm, opinions will differ from each member, however, use your best judgement. You can always contact the company itself and inquire directly w them. I've used it on my gas tank, not only on my bikes but on my cars as well. Never used it to clean the engine...
When I tore my motor down (split the cases) this past summer to do the 1250 build at 92,000 miles, everything inside was spotless.
