Bye bye PCV. Hello SESTP
My bike (2009 XL883) has been throwing out code P1009 and would die right after start up. Dealer said they could not find any problems with the bike and said it may be the PCV causing the issues. They weren't claiming that having a PCV is an issue, just that mine might have an issue. Whatever.
So i did the only thing I could at the time: bought a SESTP. (SERT sounds so much better.)
Now I'm going back and forth with the extended warranty company to cover the cost. I refuse to take no for an answer. The warranty plan expires next month and I've never had a claim. They can afford to absorb at least a portion of the cost. I bought the bike used from HD in Los Angeles and it had all of the aftermarket items on it already.
Hats off to Timpanogos HD here in Lindon, Utah. The service manager Kyle cut me a deal on the SESTP and didn't charge any labor. Also, the Dyno guy had done a bike with the same set up as mine so they loaded that MAP so that I wouldn't have to pay for that too.
The result, bike runs hard and smooth and the check engine light is gone. They must have been right on that best guess situation. Now let's see if the warranty was a good buy, or if I just donated a few thousand dollars to the retirement fund of their pool of employees.
Allen
Allen
Allen
Allen
BTW, I got my Sportster from LA Harley almost 24 years ago!
Good luck,
John
John Harper
Both I and the dealership contacted the warranty company before anything was final. Yes. The PCV was on the bike when I bought it; however, the warranty company said they only cover HD brand parts. So, any part that anybody adds that is not a stock part the extended warranty plan will not cover it.
The warranty company said no at first. I have now filed for an exception due to the fact that the PCV was on the bike and that the dealerr who sold me the bike represented the warranty in that mannor.
For the record, Sreamin' Eagle Super Tuner Pro is not even covered because it is not a street use part.
The bottom line is that the very, very, fine print states that anything not added at the factory, or by the dealership that is not HD brand street part, then you are hosed if it goes bad.
As I was typing this I got the final call. NO WAY BUDDY! I just bought myself a SESRTP! BUYER BEWARE OF THE EXTENDED SERVICE PLAN!!!!!! I know they offer towing and hotel coverage, but so does my progressive isurance plan.
Allen
Allen
Bummer they didn't cover, but it seems these extended warranties are often just a waste of money.
Your baby is running strong and hopefully long.
John
Allen
