Pipes and Air, now what tuner?
Old 04-01-2014, 12:12 PM
jdub099's Avatar
jdub099
jdub099 is offline
Originally Posted by chriscchristoph
His question is regarding the use of an xied, which will do the opposite of make his engine run lean. You're obviously not good at reading things in context.
The XIED will only make his bike not run lean in closed loop, which is everywhere but WOT. XIEDs do not have any effect on open loop operation.
At WOT, in open loop, it will run lean with Stage 1 mods. At least this was the case for me.
I have the dyno run and A/F graph to prove it.
You're obviously not good at reading comprehension in general.
Old 04-01-2014, 12:28 PM
zZeduardoZz's Avatar
zZeduardoZz
zZeduardoZz is offline
I have been reading all these things as a newbie who just got his first Harley and a lot of these things have been very helpful to learn some new things, I want to get the Stage 1 kit for my bike, and have been looking at the different opinions about XiEds and stuff, so how is that towards performance, does it change the top speed, makes the bike faster? And does the Xieds require professional installation? or you can just install that with the air kit and the pipes on your own?
thanks
Old 04-01-2014, 12:39 PM
bigmant's Avatar
bigmant
bigmant is offline
So since you have the dyno sheets, how lean is the open loop running? Is it bad enough to seriously damage the engine? I feel like I don't go WOT enough for this to really hurt the engine, and the one or two times, let's say a month, that I do I can't imagine it doing any real damage in that short of a time. Am I right or am I way off base?
Old 04-01-2014, 01:36 PM
riderboy1961's Avatar
riderboy1961
riderboy1961 is offline
Originally Posted by Dusty Bones
I punched out the baffle discs and pulled the snorkel restrictor on the ham can and drilled enough holes to get much more air at the air cleaner. l.
Dusty Bones;
What is involved to pull the "snorkel restrictor on the ham can" & Where exactly did you "drill those holes" the backing plate? Free mods I can do myself are my favorites. I already shortened my baffles to 6" long, pulled the Fiberglass packing from the muffler pipes and reinstalled the baffles with rivets. My owners manual says I can re use the stock air cleaner, its says to rinse/wash it in light soap/detergent. rinse thouroghly and let dry or blow dry. I guess the stock paper air intake filters are built different than they used to be?
Thanks
Old 04-01-2014, 02:38 PM
pjgoeman's Avatar
pjgoeman
pjgoeman is offline
Does the adaptive learn feature of the ECM happen continuosly and constantly update or does it learn for some period of time and then freeze it's settings? If it freezes should you disconnect the battery to force it to relearn after you make a modification like new slip ons, etc.
Old 04-01-2014, 03:04 PM
jdub099's Avatar
jdub099
jdub099 is offline
It is always doing it.
It's important to keep in mind that AFV is meant to compensate for things like changes in fuel, altitude, weather, aging of components- minor variations. It can't compensate for changing your intake/exhaust.
Old 04-01-2014, 04:25 PM
bigmant's Avatar
bigmant
bigmant is offline
But again, are we just talking about a slight loss of performance or something that is going to be eventually crippling for the bike? Like I said before, I'm not interested in getting peak performance, but I am very concerned about the longevity of the bike.
Old 04-01-2014, 04:36 PM
Dusty Bones's Avatar
Dusty Bones
Dusty Bones is offline
Originally Posted by riderboy1961
Dusty Bones; What is involved to pull the "snorkel restrictor on the ham can" & Where exactly did you "drill those holes" the backing plate? Free mods I can do myself are my favorites. I already shortened my baffles to 6" long, pulled the Fiberglass packing from the muffler pipes and reinstalled the baffles with rivets. My owners manual says I can re use the stock air cleaner, its says to rinse/wash it in light soap/detergent. rinse thouroghly and let dry or blow dry. I guess the stock paper air intake filters are built different than they used to be? Thanks
You can just pry it out from the front, easiest way is to pull the cover and push it out. You can't miss it. Then just drill holes where ever you can. I did a bunch of half inch and it will make a difference how much air it will get.
Stock filters will last along time washing them.
Old 04-01-2014, 04:38 PM
Dusty Bones
It is always doing it. It's important to keep in mind that AFV is meant to compensate for things like changes in fuel, altitude, weather, aging of components- minor variations. It can't compensate for changing your intake/exhaust.
That's what tuner advertisements say, gets people to buy their product. Go to nite rider and read up on how the stock Harley tune does relearn for pipes and intake.
Old 04-01-2014, 07:14 PM
jdub099's Avatar
jdub099
jdub099 is offline
Good luck with that...
Also point me to where on their website it says that it can learn for an exhaust system and intake. Couldn't find that. I did find this:
If you are one of the many motorcyclist’s that make changes to the exhaust system, air filter, camshaft(s) or other engine components, you’ll need to find a way to alter the fuel map.
I think maybe you did not understand their website.
Quick Reply: Pipes and Air, now what tuner?
