fork braces
RE: fork braces
Of course they make them for Sportsters. There are a few at this link http://www.cruisercustomizing.com/SuperBrace.cfml
RE: fork braces
Screamin Eagle has 1 for Sporties.http://www.harley-davidson.com/gma/g...bmLocale=en_US
[IMG]local://upfiles/25674/B7E9CE8A929840E8AC406CC550B6BA56.jpg[/IMG]
RE: fork braces
ORIGINAL: Broken Leg Rider
The Sportster does not need a brace.
I've had the SE Fork brace on my bike for over 10 years and never had any problems with "binding"....What ever that is?
RE: fork braces
My bike does not shimmy when stopping hard and does not twist or wobble on the turns. It does not have abrace nor does it need one. Of course it is a 91 with slightly different rake. The newer sportsters have different forks, so maybe they do need a brace.
The Dynas might need one because they are about 100 lbs heavier without a much stronger frame. The newest Dynas even come withlarger fork diameter, and the frame looks stouter too.
RE: fork braces
Fork braces aren't always installed for "performance" reasons. Some people install them for the look. That's one of the main reasons I have one on my sporty. I don't ride it aggresively enough to see too much of a performance benefit from it. I like the look. However I have noticed a differance with my bike not being pulled into ruts on the road as much as before. The fork brace that I have is the one from www.trak-tek.com that replaces the front fender. It's definately not for everyone. The short time that I've been riding with it on, I've noticed that I get more water and debris (mostly small stones) kicked up. I'm not too worried about it though. I definatly would not recomend going with any less than a full-face helmet with this brace.
RE: fork braces
If you don't believe a Sporty, orDyna/Softtail for that matter,has a good amount of flex in the front end, hold the front wheel tightly between you knees and pash hard on the bars back and forth. You will see the front forks twist quite a bit. Try it with the same bike with a brace. The flex will be nearly gone.
Sure most guys won't need one, but they willmake some improvementsfor aggressive riders.
