Quick question: Anyone running Biltwell Chumps on a 2010 48? The fit specs from Biltwell only list the Chumps fitting 2011-2013 48 models. Seems like a misprint to me but did not want to proceed without verifying. I do have a call into Biltwell but thought I would ask to see if anyone had done this install already.
They should fit, as almost any bar will fit with some effort. You'll have to change the front brake line, the switch wiring and other than that you're good
Thank you for responding BB, appreciated ... couldn't think of a reason they would not fit but here is little tidbit for other 2010 owners. The 2010 48's came out in the later half of the 2010 model year so many parts dealers really considered them 2011 (as catalogs were already printed by then) so often the 2010 48's are left off of the fit ranges, instead of 2010-2013, they read 2011-2013. Maybe this is common knowledge but as a noob, i did not know it.
