What's with the torx bolts on the sportster??
Old 03-18-2014, 10:16 AM
Jdsportster's Avatar
Jdsportster
Jdsportster is offline
5th Gear
Default What's with the torx bolts on the sportster??
I was going to put a few things on my sporty but realized the bigger bolts are torx bolts which I've heard several bad stories of stripping them. Why would HD use these bolts???? JD
Old 03-18-2014, 10:19 AM
Black Bettie's Avatar
Black Bettie
Black Bettie is offline
Personally, I've never had a problem with any torx headed bolts/screws. Usually if theyre getting stripped easily, its because the bit being used isnt a very good one
Old 03-18-2014, 10:30 AM
stereoguy's Avatar
stereoguy
stereoguy is offline
Or they tried to use an allen wrench in place of the proper torx bit.
Turbinesaint's Avatar
Turbinesaint
Turbinesaint is offline
I know that many people on here will replace them with different bolts as they do some regular maintenance. I haven't had too much trouble with them, I think the last one I had issues with was my own fault. Replacing the bolts is a fairly cheap solution if you don't want to mess with the torx bolts.
Old 03-18-2014, 12:37 PM
Jdsportster
5th Gear
I'm going to to get the saddle supports, guess I'll get a good set of wrenches from harbor freight
Old 03-18-2014, 04:14 PM
run1fsr's Avatar
run1fsr
run1fsr is offline
Appearance. Far more pleasing to the eye than a row of misaligned hex head bolts.
Old 03-18-2014, 05:28 PM
slyedog's Avatar
slyedog
slyedog is offline
Exactly. I bought SK Tools Hex and Torx just for my bike. Also when using extensions with rachets and so forth must stay centered. I have had zero problems since I upgraded to SK from the craftsman I had before. Even then it was the hex that fought me not torx. Quality tools are a must to service these fasteners.
Old 03-18-2014, 06:02 PM
heybaylor's Avatar
heybaylor
heybaylor is offline
LOL, I'm sorry , but are not we getting a little "****" about looks ????
Old 03-18-2014, 06:12 PM
baka1969's Avatar
baka1969
baka1969 is offline
If you use a good set and the correct size while using care you should be alright. Make sure you have a T27.
Old 03-18-2014, 06:27 PM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,250 Likes on 1,641 Posts
Just use the "proper" tool for the job and you'll be fine. Torx bolts won't strip if you have correct size bit and don't apply too much force (i.e. air wrench). No need to worry.
Quick Reply: What's with the torx bolts on the sportster??
