Stripped shock bolt
Stripped shock bolt
So I was switching out my stock shocks(2005 883) for some air shocks and stripped the crap out of the left bottom shock bolt! I want to kick the inventor of Torx bolts square in the nuts with a bionic leg!!! I'm gonna go at it again after work tomorrow and see what I can jimmy rig to get that sucker out.
If you aren't able to get it out, drill a hole in it and use this:
http://www.beta-tools.it/catalog/art...eta/__filters_
Location: In the foothills of southwestern NC - US of A
Here'a a trick...allen wrenches can sometimes be substituted for torx, so place a suitably sized allen wrench in the blown out hole...now use a centerpunch to strike around the bolt head to force the surrounding material back towards it's original shape "around" the allen wrench. Don't be a sissy about it, whack it into shape real good. 'Looks like hell when you're done but it works; you'll be replacing the original fastener anyway.
About drilling...drilling out the bolt is ok if you're real good at keeping the drill bit centered on the bolt, along with knowing how close you can come to the original female threads without ruining them. It's simply a matter of patience and observation.
I've had lots of success with welding another bolt right onto the head of the offending bolt. This works for a couple of reasons...the heat generated from welding goes into the threads and expands them, compressing whatever is inbetween them...then when the fastener cools down, it shrinks, leaving ample space between the male and female threads making it easier to remove. The heat will of course be beneficial also when encountering thread lock compounds.
=8^)
