need shocks!!!
Depends on your budget. Progressive products are great and they have shocks for for every budget. I took some good advise from members here and recently put some 412's on my Iron and I'm extremely pleased.
**Edit** I also did my front springs at the same time, again used Progressive, and the front forks don't dive and eats the bumps much better too.
Hi from the UK and welcome to HDF. You'll find that shocks get plenty of discussion in here, if you care to look back through recent threads. There are also many possibilities open to you. In the case of my SuperLow, a sort of 883 version of your bike, I have raised the suspension at both ends and fitted longer new shocks.
There are three problems we suffer from. One is that sag in the front forks takes up much of the total fork travel (unless you are feather light!). Another is that with low ride height the rear shocks have very little total travel. Finally, the quality of damping at both ends is very poor!
The front end can be improved by simply restoring ride height, so that sag is reduced to around 1/3rd of total travel (on my bike sag was 2/3rds when new). I have Hagon shocks, but there are many other brands.
Mustang seat and 13" shocks on my 1200 low made a magnitude of improvement - also replaced the stock fork oil with SE, but the springs are still stock. For any further perceived improvement it would probably take higher end (and more expensive) shocks (these are standard HD shocks). For that kind of money I'd rather buy a 2->1 exhaust. But if you weigh a lot or ride two up the high end shocks might be justified.
Lots of people swear by installing the RK air shocks - just don't like the look of them so didn't go that route.
Ride quality and suspension is a popular subject across the entire range of Harleys. The plain fact is that the MoCo cheaps out on suspension for all but a few models (like my FXDXT), leaving us with the challenge of sorting the problem out. Even on the more expensive bikes it is a sensitive subject, as the solutions are - you guessed - expensive! For Sporty owners the cost is proportionally even more expensive, relative to the cost of the bike. Unfortunately I have yet to read a definitive discussion that we can all point to, that provides us with the solution on a plate.
thanks
I just need some handle bar risers and I'll be all dialed in!
