XiED were installed but have a question?
So I went to install xied's on my 2010 forty eight, the terminal connector for the rear oxygen sensor has a wire not connected, only one of the wires goes into the back of the connector. The other one has no terminal pin attached to it. Like it is suppose to just be there.
I'm not sure if this is suppose to be like this or did someone disconnect or cut the pin off.
I look at my girl friends 07 custom and hers has both wires going into the back of the terminal connector.
Anyone installed XiED and found this to be the same?
The rear oxygen sensor it's the pink/green wire, the other wire is a black/white wire.
I have a wiring diagram for a 2008, it shows the blk/wht wire to be 5V ground and the pink/grn to be oxygen sensor B at the ECM. It is the pink/grn wire that has no pin to connect to the connector.
This bike I bought last year from a Harley Dealer out of state, as new but with no warranty because of its age. The bike was a photo bike that Harley used and then auctions off to dealers for sale.
I am hoping someone out there has installed and can verify on there 48 that this pink wire is in fact connected to there connector?
