Help me decide - New air intake
So I've been having a really hard time deciding on a new intake for my bike.
I'm currently trying to decide between the SE Stage 1 round intake or the RSD venturi.
The main reason I'm not hot on the SE is the apparent lack of cool covers for it. I'm considering building my own but not to sure on any ideas for it.
Anyone have experience or reviews of the RSD intake? I'm putting it on a 2013 48 with forward controls.
I've also looked at the DK customs cleaners. They have some cool looking stuff but I'm a bit put off by the breather bolts setup.
Any advice or ideas would be appreciated. Thanks.
I have one of dk's outlaw ac with the clear cover which I like a. Lot. Rsd's clarity line is pretty awesome and I wanted something like that. As far as the breather bolts are concerned they don't make the bike smell significantly different than before, ya it's more noticeable but it isn't bad, and I have pretty sensitive nose. Aside from that they have another set up with a filter tube that ends in an air filter running down the bike and dumping that air near the frame if you don't want to have the breather bolta blowing on you. I get some misting but only when I'm hammering it and riding a little more crazy, around town never. Full up use the gas station squeegee and its gone, not noticeable on pant legs either. If you have the money and like the style of red, turbine looks cool also, do it but they are just as effective and good looking ac's out there.
Received 4,196 Likes
You can choose to have the filter terminate anywhere you want. Here's where I have mine on my Sporty.
Whatever A/C you get, I recommend that it not vent the hot oily air into the intake, both for performance reasons and for long term issues. Below is a typical look at what happens if you do-
That's where the discrete breather system comes into place. It vents to a filter that you can put virtually anywhere on the bike.
__________________
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
www.DKCustom.com
662-252-8828 Voice
I have the RSD Ventura Speed 5 on my 48 and like it. My friend made me the brass spacers and also powder coated the cover in brass and black. If you get 1, ask them for the air cleaner retro fit kit breather tube upgrade kit. #0206-4002. It's free from them but doesn't come with the a/c kit.
retro fit kit # 0206-4002
Location: In the foothills of southwestern NC - US of A
Yo fishwacker,
I hemmed and whored about an intake for months. The round designs, although functioning well, I found to be cheezy looking and repetative. Not liking these designs led me down another corridor, to the K&N Air Charger Part #63-1126...just look at the filter surface area:
http://www.knfilters.com/search/prod...x?prod=63-1126
I've been running mine for two years, without any cover, through numerous rainstorms, and it's done just fine. Twice I've cleaned/reconditioned it and it's no worse for wear as a result.
The only small issue with this setup is that [crankcase] oil vapor is returned via the assemblies "U" pipe back to the engine through the intake, so I fab'd up a relatively simple and inexpensive solution so the engine could vent to atmosphere...see link below.
https://www.hdforums.com/forum/sport...ather-mod.html
I simply deverted the oil vapors from the "U" tube down to a stainless steel filter that I mounted at the base of the engine between the jugs that has yet to show any signs of oil whatsoever. I covered the 3/8" OD port that was originally used to recieve vapors back to the intake elbow with a simple blank-off vacuum cap. Voila'.
The K&N Air Charger has a good reputation and looks bitchin' to me. It's "similar" in design though not the same as the HD Heavy Breather, which has internal breather bolts that return the crankcase ventilation vapors to the engine via an inclosed design. At least with the K&N you have an easy alternate method of re-routing these vapors to atmosphere or catch can should you wish to do so.
And contrary to popular belief, the K&N doesn't stick out much more than the stock ham can. As such I don't have any issues with right leg interference.
=8^)
=8^)
