Grip change question
The throttle side grip is "one piece" and can be re-used. But since your getting new bars and new KungFu grips you will need a new throttle tube (looks just like the org part minus the grip). You will slide the new KungFu grip on there and attach the throttle wires and ferrules then slide the clutch side grip right on the bar. The grips have a clutch side fit (a 1" hole) and a throttle side fit with a bigger hole to accommodate the throttle tube. The outside diameter of the grip are the same though.
Biltwell has these...
http://www.biltwellinc.com/index.php...t_detail&p=119
The reason the dual whiskey won't work is because that used when you delete the switch housings to clean up the bars.
Good luck!
It is easier to get a new tube,i did not and had to fool around getting the glue off the old one,and the grips are two sizes one side is 1" and the side that goes over the tube is 1 1/8"
They do not go inside the housing just butt up against it,so the next time you change them
you do not have to remove the screws,just cut the old ones off and put the new ones on.
