4.5 Tank Usable Fuel
I've been riding my 2013 1200 Custom (4.5 gallon tank) for almost two months and I've been trying to stretch out how far I can go before a fuel stop. The low fuel light comes on at about 105-110 miles and at that point it will only take a little less than three gallons. I stretched it out to about 150 miles and it took about 3.5 gallons. On my last tank it started to sputter and cut out while accelerating after 160 miles. I stopped to fill up and it only took 3.7 gallons. Is it normal to have that much gas left in the tank and have fuel pickup problems? It wasn't fun to be taking off from a light and then feel like you're going over the front end because the motor pretty much shut off.
Yep. Most common reason for failure in fuel pumps is running tank too low. I always fill bike around 120 miles or so. Mine did the same as yours the one time I tried to go 30 extra miles. Will never go that far again before refill.
doesn't seem too normal...I have and 04 883 with the 1200 kit with a 4.5 gal tank and sheesh, I'm not turning on my reserve until like 175 miles, and could probably squeeze 200 out of a full tank if I ride like I have some sense...But then again I'm not sure how the EFI bikes work, I think a carbed bike is more accurate...the most i've gotten out of a tank was like 190 miles and I think i end up putting about 4 gal in it
I have 4,5 and the most I have gone without a fill-up was about 160 miles but I did not experience any issues. I think it was about 3.8 gals to fill up when I did that. Normally I'll be looking for gas at around 140. But its nice to know I could probably go another 30 miles or so if I needed to. I don't think I'd want to try and run it out of fuel for obvious reasons.
