2013 48 sensor in switch housing
so I have a 2013 48 and I took apart the switch housings bc I wanted to get rid of all the switches on the handle bars and move them but there is a button on both housings does any one know what they are for. Also I cant seem to get the throttle cable out the housing either but the idle cable comes out just fine.
If anyone can help me out thanks.
About the throttle cables, loosen them up first so that you get some slack, unhook them inside the housing, remove the ferrule and the just pull them out. Mine where seated pretty hard so you might have to use just little bit of muscle to pull them out.
Btw, if you're talking about the throttle side there's a switch inside the housing, that's the brake switch. Pull the break and your light comes on.
yes that's the one. have eliminated all the switches on the handle bars and relocated them to the battery cover but now I don't know what to do about those but I will post pics today
Whiffleboy
07-13-2007 11:49 PM
