1200 Sportster 1992 low miles not started for 20 years
Sounds interesting. If the price is right and it's in decent shape, give it a shot. Put in some new oil, squirt a little in the cylinders, charge the battery and see if she fires. Run some Seafoam through the tank and carb. Who knows?
John
John
I would buy it...before starting it i would change the oils and battery, pull the plugs and spray some CRC power lube in the cylinders and pull the air cleaner and spray a good amount more CRC in the carb. making sure to get it in all the little holes in the carb body and on the butterly shaft and the slide, then I would let it sit over night to soak in, while waiting I would check all the electrical connections for corrosion and give them a good spray with the CRC (it won't hurt nothing), pull the gas tank off and dump it and give it a good rinse with gas and dump it again, reinstall it and add a gallon of gas.. then I would turn it over ( the motor, not the bike) with the plugs out a few times...reinstall the plugs and try to start it (outside, as it will prolly smoke like crazy)....if it starts, take a good look at the brakes, tires and wheel bearing and if all looks good go fro a short ride...then come back here and tell us how it went...
leaky
03-23-2016 08:55 AM
hdtwice
11-24-2012 07:35 PM
