Reverse Mount Mirrors
Hey all, first time posting in a while. I'm going to be getting an 06 sporty 1200 soon and was thinking about reverse mounting the mirrors to give it a little more custom look, plus I think that they look wicked. Just wondering how big of an undertaking it'd be and if anyone else has done, if so, I'd love to see some pics!
Just take them off and switch sides. Tricky part is getting them set right afterwards. You may have to loosen and rotate your controls to line them up where you can see. I am 6' with wide shoulders and I can see much better with them on the bottom as I am not trying to see around my shoulders now. There might be some pull back bars that will make it impossible to adjust them properly on the bottom. Try it and see, not a big deal at all, just takes some time. If you try it and have trouble just post and I will try to give more detail.
it really depends on the receivers, if they have a plug on the bottom - take the plug out and reverse it to the top then screw the mirrors in from the bottom, the left mirror becomes the right mirror and right -left. The receiver needs to go all the way through (if they don't you can flip them).
On adjustment leave the adjustment screw semi-snug - turn the handlebars to the left and make sure you have no more or less than one finger gap between the tank and the mirror, repeat for the right side. I have found a short to medium mirror steam works far better than a long steam.
I love the look, and from what I've read, most people agree that they're more useful with an under-mount. Hopefully, I'll have my bike soon, just gotta talk to some people and go get it! It's still cold as a witch's tit around here, so I'll have some time to play around with the look before actually getting to ride. I'll probably take it out as soon as it gets above 40 degrees lmao
