Reverse Mount Mirrors
On mine at the time I was running 32" drag bars with the stock risers (1" I think). I've kept them flipped and I've now got RSD clip ons....Nightster does give you a bit of extra room though. My Dad's was the 110th Anniversary with the stock mirrors and bars. It was damn close and you'll be limited with adjustment angle but, he and I are only 5'8 so it was ok. If you've got big ol' legs it might be a problem seeing past them....give it a try. Only takes two minutes.
Drag bars don't come as far as the pullbacks either... which might contribute to it fitting. Also, I'm pretty sure the nightster didn't have a 4.5g tank... pretty sure it's a 3.3g.
Ah sorry, didn't realise you'd already tried. That's so weird they don't fit. Do the mirrors just hit the tank on lock then? Even after adjusting the heads? Did you try adjusting the angle as well as the head? If you have and still have no luck, my Dads was a 2013 ......maybe it has slightly shorter stalks? Can't imagine it though. He traded it in for a Wide Glide and the dealer's not picking it up until tomorrow so I'll go over and flip the mirrors and take a photo for you.
It's chilly today so I probably won't ride... maybe I'll try again.
I just flipped the stock mirrors on my 2013 1200c a couple of weeks ago and it worked just fine. Not to mention it improves the overall lines of the bike IMO. The mirrors are more user friendly as my shoulders are no longer in the way. I flipped stock mirrors and have the 4.5 gallon tank with plenty of clearance. You may have to adjust the angle of the stem to gain proper clearance. The stock pullback riser and stock pullback bars are still on the bike.
Ok, just went and flipped the mirrors again and it's definitely fine mate. As Johhny said, you have to play with the stem angle but it should be fine. I took some pics so you can see the angle.... <iframe width="480" height="360" src="http://s562.photobucket.com/user/Gojugaijin/embed/slideshow/Mobile%20Uploads"></iframe>
Hope this helps! Oh if that link doesn't work, it might be this one:
http://s562.photobucket.com/user/Goj...bile%20Uploads
Hope this helps!
Hope this helps!
