Modular, did you do anything to the front, did belt need to be adjusted?
Yes, I did do some work to the front end. I installed RaceTech springs, Roland Sands adjustable preload fork caps (for ease of setting preload/sag) and dropped the fork tubes until flush with the top tree.
I checked the belt tension with a belt tension tool and it was still within spec nicely.
I have 13" Progressive 412's installed. I did it to quicken up the steering, gain lean angle and for better ride quality. Accomplished all 3.
Requested pics:
Thank you sir! Great looking bike. It looks nice with the longer shocks. Any thoughts/advice about just swapping the rear shocks without the front end work, at least initially?
