2004 Roadster speedo problem
I am having a problem with an intermittent speedo and have had it to Harley as well as putt a few hours myself into trying to solve the problem.
the questions I have are 1. Has anyone heard of braided steel plug wires causing this type of issue. 2. any other suggestions? At this point I have switched out and tested ( with known good components) the speedo , ignition module and checked voltages.
I have ordered new plug wires already as I do not like the look of the braided ss covered ones . Any thoughts ?
It would help if you told us what about the speedo is broken. Does it stop measuring speed or does it go dead, as in no power?
Out of all the parts listed that have been replaced, I don't see the most obvious part related to speedo issues, which would be the VSS.
VSS was also tested and tested good
By intermittent I mean the speedo will work fine for a few miles and then drop off to zero and for no obvious reason start working again. Bumps in the road or temperature do not seem to play a part.The back light stays on and the Tack works fine no problems ( This is a Roadster model ).
